gc8guy Posted January 19, 2010 Share Posted January 19, 2010 It's a 1994/10 Legacy twin turbo BG-5 This happens very randomly under throttle I will accelerate from a standstill get to about 40-60km/h and let go off the gas a little and my revs drop to about 1 rpm I try to accelerate again to get the rpms back, but I just hear the engine reving, occasionally I can get the rpms back and get the speed back, but when this happens and the revs drop below 1rpm I get a check engine light. I pull over, restart the car everything is fine again, then It happens 30 minutes or 1 hour later under throttle..... any thoughts ?? the car has just over 100k.. at first it started happening when I was turning and accelerated from a standstill more info : as I accelerate and build up boost I constantly hear a strange noise, the best way I can describe it is: Imagine a blow off valve building up air as you accelerate, but releasing air in small bursts constantly and I can hear the constant releases. Link to comment Share on other sites More sharing options...
gc8guy Posted January 20, 2010 Author Share Posted January 20, 2010 here is the video it sounds like some sort of a leak, but not sure if it has anything to do with the problem also, there is a water moving-type noise going down a pipe or a hose right behind my climate control under throttle sometimes and when I'm turning which I thought was power steering fluid at one point Login to a private Photobucket.com album Link to comment Share on other sites More sharing options...
