svgt Posted January 19, 2010 Share Posted January 19, 2010 Has anyone uncovered a common exhaust leak on the 05 lgt? I am having trouble reaching the boost levels I think I should be at and before I put her on jacks in January I figured I would send this out. I do have a Perrin DP and she is torqued right. I have checked for vacuum leaks and connections and they all seem good. This is my next step. I may be fooling myself but I think I can hear what sounds like a leak but I am not sure from where. Any ideas? Link to comment Share on other sites More sharing options...
m sprank Posted January 21, 2010 Share Posted January 21, 2010 Most common is the uppipe. But if you have not messed with it... What boost levels are you trying to hit? Link to comment Share on other sites More sharing options...
svgt Posted January 21, 2010 Author Share Posted January 21, 2010 Well I am really trying to get to 18-19psi. I have been in the low teens to 13psi max. I had the turbo replaced about 10k ago with the common banjo bolt fault associated with these. I had not had a cobb prior to that to compare boost levels before and after but it feels the same. You mentioned an up-pipe leak. Is that with aftermarket up-pipes or stock? I had planned on buying an aftermarket one and while installing it check the other connections for leaks. Link to comment Share on other sites More sharing options...
scoobydoobie Posted January 21, 2010 Share Posted January 21, 2010 what are your mods? Link to comment Share on other sites More sharing options...
m sprank Posted January 21, 2010 Share Posted January 21, 2010 Yes, need more info. You have a leak or a hose is off. Like the one off the BPV that goes to a tee under the IC. Link to comment Share on other sites More sharing options...
svgt Posted January 22, 2010 Author Share Posted January 22, 2010 Mods are Perrin DP, Full borla, Perrin TMIC, AEM CAI, and TA Stage II map. I checked the t under the IC and the other lines associated and they are all good. Link to comment Share on other sites More sharing options...
