posco Posted January 19, 2010 Share Posted January 19, 2010 Hi, I've got a problem with my ABS on my Subaru Legacy GX 1992. It randomly turns itself off. Just randomly when I'm driving, the "antilock brake" lamp lightens, and the ABS ain't working anymore. Could someone here help me with this problem? Sorry for bad english, but I still hope you can help me with my problem^^ Haakon Link to comment Share on other sites More sharing options...
ehsnils Posted January 19, 2010 Share Posted January 19, 2010 It is probably a sensor that is malfunctioning. Not easy to figure out which one, but inspect the cabling to each sensor and also check if the teeth in the rings at each wheel are complete and relatively clean. It can also be problems with oxides in a connector so disconnect each connector, clean it and reconnect it and see if it helps. Link to comment Share on other sites More sharing options...
whitetiger Posted January 19, 2010 Share Posted January 19, 2010 +1 to it being a wheel sensor. Link to comment Share on other sites More sharing options...
posco Posted January 20, 2010 Author Share Posted January 20, 2010 Thank you!I will surely check it out. And I'm very happy that I've found a active Subaru forum. It's not so easy to find^^Again thanks:) Link to comment Share on other sites More sharing options...
dmanaenk Posted January 20, 2010 Share Posted January 20, 2010 ^ bbs.legacycentral.org is a lot more active for first generation car questions. And ABS light could mean totally unrelated stuff. Check if your alternator is producing right voltage. These fail frequently with age and cause ABS to illuminate occasionally before dying. 666 Link to comment Share on other sites More sharing options...
sqc151 Posted January 20, 2010 Share Posted January 20, 2010 definitly check out legacycentral.org... but search a bit first before posting. lots of info there. Link to comment Share on other sites More sharing options...
