beaterwagon Posted January 15, 2010 Share Posted January 15, 2010 Well my CEL is on and throwing a evap emissons control system malfunction and the filler pipe is leaking. Are these two related? will fixing the pipe solve it? I'm still pretty much a newb with subaru's and new cars (all cars to date have been carburated. Any help is appreciated. Edit: just realized i typed in instead of on. Link to comment Share on other sites More sharing options...
ehsnils Posted January 15, 2010 Share Posted January 15, 2010 That seems to be a related fault. The evap malfunction code tells you that there is a leak in the ventilation of the gas tank, which you obviously have figured out! Link to comment Share on other sites More sharing options...
beaterwagon Posted January 15, 2010 Author Share Posted January 15, 2010 cool thanks now to wait for some dry weather to repair it Link to comment Share on other sites More sharing options...
rmb2485 Posted January 15, 2010 Share Posted January 15, 2010 Most of the time that code just means your gas cap isn't tight, but since you know the filler pipe has a hole/crack I'd say that's your problem. Link to comment Share on other sites More sharing options...
