peteyjr Posted January 14, 2010 Share Posted January 14, 2010 Changed my oil yesterday and started fiddling with the stock endlinks (tried to remove one as I am in the group buy for the MSI units). Noticed the stock links are pretty shot mated up to my Progress bars. I stuck a 12 mm socket on them and lo and behold, they spun without ever loosening. Anyone ever have this problem. I'm going to have to Dremel them out it looks unless someone has a better idea. Link to comment Share on other sites More sharing options...
yamie700 Posted January 14, 2010 Share Posted January 14, 2010 You have to put an allen wrench in the middle and hold that while you have a box end wrench to spin the nut off. I had one of the allen recessed areas strip out though, and had to get creative to get one of mine off. Link to comment Share on other sites More sharing options...
TRS Posted January 14, 2010 Share Posted January 14, 2010 I believe there is a opening in the end of the bolt to insert a hex key to keep it from turning while you use a box or open end wrench on the nut. Let soak with a Liquid Wrench or PB Blaster type penetrating oil first. Link to comment Share on other sites More sharing options...
peteyjr Posted January 14, 2010 Author Share Posted January 14, 2010 Thanks, The rust on the bolt was hiding hex openning. Makes sense why I couldn't pull them. Looking forward to replacing these flimsy little friggers Link to comment Share on other sites More sharing options...
