tonyalive Posted January 12, 2010 Share Posted January 12, 2010 anyone know which fault code reader i should buy for my 1995 legacy gt 2.0 twin turbo ?is it the obdII ? cheerstony Link to comment Share on other sites More sharing options...
ehsnils Posted January 12, 2010 Share Posted January 12, 2010 If you have a contact near the fuse box in the footwell of the driver that looks like the bigger contact on the page in this link: http://www.interfacebus.com/OBDII-to-DB9-pin-cable.html you do have it, otherwise not. If I'm right it depends a bit on which market you are on, brand and model if the car has OBD-II in '95. Link to comment Share on other sites More sharing options...
rmb2485 Posted January 12, 2010 Share Posted January 12, 2010 I think OBDII started in 1996, but just go look and see if you have the OBDII connector behind a little door in the dash, under and to the left of the steering wheel. As for a code reader, I have the more expensive one of the two Harbor Freight offers and it works great. Link to comment Share on other sites More sharing options...
