deer3 Posted January 31, 2010 Author Share Posted January 31, 2010 i bought a serial to usb adapter for the cobb cord and im running it on an xp pc wont work Link to comment Share on other sites More sharing options...
mwiener2 Posted January 31, 2010 Share Posted January 31, 2010 you've got some issues with the computer than. Not uncommon at all. try a different computer. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Ridgeracer Posted January 31, 2010 Share Posted January 31, 2010 did the serial to usb adapter come with a driver disc? If not search online for a driver for it. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
deer3 Posted February 2, 2010 Author Share Posted February 2, 2010 well it looks like imma have to wait for a tactrix cable because all my attempts to get this cable to work have been unsucessful...and if you can believe it my local subaru dealership is too afraid to check out the car and by their own words not qualified to diagnose turbo problems Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 4, 2010 Share Posted February 4, 2010 easy way to check for boost leak is spray ether ( starting fluid ) on your boost hoses , if the idle picks up it could be a boost leak and you should check where you just sprayed , i did it to mine earlier after i installed my vac/boost gauge and MBC just to make sure everything was tight exact hoses = from the wastegate to the vacuum on the compressor housing and the hose that runs to your BPV or BOV or w/e u have Link to comment Share on other sites More sharing options...
mwiener2 Posted February 4, 2010 Share Posted February 4, 2010 ^^ you won't find a boost leak with starting fluid. Especially smaller leaks, they tend to be sealed at idle and low load. They don't start leaking till higher pressures. Vacuum leaks can be found with fluid though. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 4, 2010 Share Posted February 4, 2010 ** noted ** Link to comment Share on other sites More sharing options...
cfdrumr Posted February 4, 2010 Share Posted February 4, 2010 I had the exact problem one time. Try a few things Unplug the hose right at the wastegate. DO NOT PUSH THE CAR HARD!!! See if you will boost over 10psi. The spring in the waste gate is 11psi i think. I had a problem once when i overboosted... the computer pulled all the boost and I could only hit wastegate pressure. If you are boosting, then it is a computer/hose problem. Also, unplug your battery and let the ECU reset. Should take care of it. Link to comment Share on other sites More sharing options...
deer3 Posted February 4, 2010 Author Share Posted February 4, 2010 if i unplug the battery lets say for a few mins will my maps on the ecu still be there? might be a dumb question but i have to ask Link to comment Share on other sites More sharing options...
deer3 Posted February 4, 2010 Author Share Posted February 4, 2010 also how long do i leave it off for to reset it? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 4, 2010 Share Posted February 4, 2010 if you have an AP, the basemap will be saved, the realtime will get dropped. Unplug battery, hold down brake pedal for 10-15sec. that will reset ECU. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
deer3 Posted February 5, 2010 Author Share Posted February 5, 2010 so my innovative tuning base map will be gone? Link to comment Share on other sites More sharing options...
mwiener2 Posted February 5, 2010 Share Posted February 5, 2010 did they use the COBB accessport to tune your car? My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
deer3 Posted February 5, 2010 Author Share Posted February 5, 2010 unknown...was done by previous owner Link to comment Share on other sites More sharing options...
mwiener2 Posted February 5, 2010 Share Posted February 5, 2010 Well until you figure out who tuned your car with what... you really can't do much It's also possible your turbo died. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Darkness of Death Posted February 5, 2010 Share Posted February 5, 2010 i've filled in some of those questions/concerns Link to comment Share on other sites More sharing options...
WTBmoreboost Posted February 7, 2010 Share Posted February 7, 2010 on this subject what is the factory boost number , ive heard 5 but not sure i got a MBC and it reads 13 under load ( gauge is probly off a bit ) after i tinkered with it Link to comment Share on other sites More sharing options...
