Turbo kit for 99 legacy wagon
I guessing 2.2 liter? There are bolt on kits made from ..... Drawing a blank on the name........ that you can use your stock block, I would not recomend bolt on kits until you build the engine to handle the power. There could problem with the engine that will cause it to blow it if not careful.
The kit is called the AVO Turbo kit for impreza n/a 2.5
http://www.rallitek.com/avo25turbokit.html
But have fun with that price tag. Also a word of advice is that due to high compression N/A motors makes its hard to hard to have any fun boost such as 15 or even 20psi, so your stuck with a good max of 6psi for safety but hey from the numbers they tell, sounds sexy.
