pet Posted January 10, 2010 Share Posted January 10, 2010 Hi My son has a 94 rs legacy that cuts out occasionally and has just started smoking ( blue) also surging between 2-3k revs -- Any ideas ? Link to comment Share on other sites More sharing options...
ehsnils Posted January 10, 2010 Share Posted January 10, 2010 Too many ideas - is it a turbo? (hard to keep track of all models etc.) If not - then it can be all from a ringland failure to something wrong with the crankcase ventilation. If you have a turbo it can be the turbo too. A simple check - remove all spark plugs. If all are equal then it's probably a generic failure. If you have one plug that's oily or clogged you have a problem with that cylinder. And then it can be problems with the cylinder heads/gaskets too. Hard to really know what from the short description you give. Link to comment Share on other sites More sharing options...
pet Posted January 11, 2010 Author Share Posted January 11, 2010 thanks Ive since found its a blown primary turbo Link to comment Share on other sites More sharing options...
