Baddog Posted January 9, 2010 Share Posted January 9, 2010 The boot on this is torn. What is it? And would it cause an annoying sound when you slightly turn to the right/left? http://img197.imageshack.us/img197/1103/svq35u.jpg Link to comment Share on other sites More sharing options...
dmanww Posted January 9, 2010 Share Posted January 9, 2010 It's a tie rod. It moves the wheels right and left when you turn the steering wheel. You have a torn inner tie rod boot. Link from another forum- http://www.ultimatesubaru.org/forum/showthread.php?t=66318 Link to comment Share on other sites More sharing options...
ehsnils Posted January 9, 2010 Share Posted January 9, 2010 It's a very good idea to replace that boot - and to clean and lubricate before the new boot is put on. Otherwise your steering may go bad. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted January 9, 2010 Share Posted January 9, 2010 It's a very good idea to replace that boot - and to clean and lubricate before the new boot is put on. Otherwise your steering may go bad. Lol, mine's been torn for like two years now and still running strong! Need more munies!!! But yeah, don't do what I do. Fix it. Link to comment Share on other sites More sharing options...
rmb2485 Posted January 9, 2010 Share Posted January 9, 2010 Make sure you get an alignment after you replace the boot (and any other time you mess with suspension or steering components). Link to comment Share on other sites More sharing options...
dmanww Posted January 9, 2010 Share Posted January 9, 2010 yeah, or you may end up with a wonky steering wheel like on mine. Link to comment Share on other sites More sharing options...
Baddog Posted January 9, 2010 Author Share Posted January 9, 2010 Okay so what all would I need to pick up exactly to get this fixed?I normally go to autozone cause its local or can go to napa. Link to comment Share on other sites More sharing options...
rmb2485 Posted January 10, 2010 Share Posted January 10, 2010 You'll need a new rack and pinion boot and some grease. Easiest way to change it is probably to disconnect that steering link from the knuckle and slide the new boot on. edit: And according to the FSM, the grease you need is "VALIANT GREASE M2" which I assume you can only get at the stealership for probably a few thousand bucks an ounce. Link to comment Share on other sites More sharing options...
Baddog Posted January 10, 2010 Author Share Posted January 10, 2010 Something like this? Do I need a new inner tie rod as well? http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=181169_0_0_7736&skuDescription=Duralast+/+Rack+%26+Pinion+Boot+Kit&brandName=Duralast&displayName=Rack+%26+Pinion+Boot+Kit&categoryNValue=14699999&sortType=&store=2225&isSearchByPartNumber=false&fromWhere=&fromString=search&counter=0&itemId=1091-0&navValue=14601091&filterByKeyWord=pinion+boot&productId=181169&searchText=pinion+boot&categoryDisplayName=Suspension+%26+Steering&parentId=46-0 Link to comment Share on other sites More sharing options...
slickfast Posted January 10, 2010 Share Posted January 10, 2010 Can you guys really see a crack in the steering rack boot? I'm not seeing it... Describe the annoying sound please. Is it a clicking noise the remains once you're at a certain steering angle? If so, it's not the steering rack at all. Check both sides and make sure your drive axle boots are all fine. Link to comment Share on other sites More sharing options...
Baddog Posted January 10, 2010 Author Share Posted January 10, 2010 Can you guys really see a crack in the steering rack boot? I'm not seeing it... Describe the annoying sound please. Is it a clicking noise the remains once you're at a certain steering angle? If so, it's not the steering rack at all. Check both sides and make sure your drive axle boots are all fine. This is my fault. This is just a picture on google I found of someone taking their hub apart. I never took a picture of my car. The one on mine is ripped in half. I have replaced both CV boots about 3 weeks ago. Link to comment Share on other sites More sharing options...
slickfast Posted January 11, 2010 Share Posted January 11, 2010 aHAH. That changes things. In that case I would clean it, grease it, and hope that I didn't fix it too late so that permanent damage has occurred. Keep us posted. Link to comment Share on other sites More sharing options...
Baddog Posted January 11, 2010 Author Share Posted January 11, 2010 If I did cause permanent damage what all would I need? Link to comment Share on other sites More sharing options...
hrmjay Posted January 12, 2010 Share Posted January 12, 2010 Hi, Thats a track rod end (also called a tie rod end). The noise you describe while turning is most probably a worn CV joint. The louder the clicking the more severe the noise. A slightly worn CV can be rejuvenated with a thorough clean up and plenty of graphite grease plus a new axle boot. If the noise persists the CV joint needs replacing. Link to comment Share on other sites More sharing options...
Baddog Posted January 12, 2010 Author Share Posted January 12, 2010 CV Joints were replaced awhile ago. Link to comment Share on other sites More sharing options...
slickfast Posted January 13, 2010 Share Posted January 13, 2010 so did you fix this yet or what? Link to comment Share on other sites More sharing options...
Baddog Posted January 14, 2010 Author Share Posted January 14, 2010 No, waiting to find out exactly what I need. It's been like this for 3 months now. I don't want to go get the wrong parts to take it apart. Seems like an easy replacement though. Link to comment Share on other sites More sharing options...
