Guido98LGT Posted January 7, 2010 Share Posted January 7, 2010 Hey Guys I'm in a bit of a predicament. I'm attempting to replace the water pump, timing belt etc on an EJ25 out of a 98 Lgt. The only thing is I can't seem to break crankshaft pullet free. If it were in the car I'd just leave it in park and blast away with the impact gun but it's curently out of the car. I did a little research and found this tool http://www.denlorstools.com/home/dt1/page_35561_609/kent_moore_spx_499977000_crank_pulley_wrench_subar.html now I don't mind purchasing it if I need it but I was wondering if anybody has a cheaper way of doing it. I know it looks like a simple tool but I just don't have the ability to recreate one so that idea is already out the window. Link to comment Share on other sites More sharing options...
01rs25 Posted January 7, 2010 Share Posted January 7, 2010 What I usually do... Undo two of the flywheel bolts across from one another and stick a large screwdriver, metal rod through the accesplate and in between the bolts and crank away.. Works like a charm everytime! Slammed more than your girlfriend. Link to comment Share on other sites More sharing options...
meier motor sports Posted January 7, 2010 Share Posted January 7, 2010 or. a prybar. large screw driver in the teeth of the flywheel. or a nifty trick i saw on here using the belt. to lock the pully down Link to comment Share on other sites More sharing options...
DN1911 Posted January 13, 2010 Share Posted January 13, 2010 Kent-Moore tools, Google or E-Bay them for the factory pulley remover Link to comment Share on other sites More sharing options...
trevorno Posted June 30, 2010 Share Posted June 30, 2010 Following this thread, I put a stainless steel bolt through the flywheel inspection hole and cranked away on the pulley. The bolt was about 5" long and only had about 1" showing before I started wrenching. It felt secure in there. Once I started wrenching, I thought the bolt was starting to give, but it turns out the bolt I stuck in there was giving. Now, It's stuck in the inspection hole and I can't pull it back out. It seems like it's bent & stuck in there. It seems I'm in deep doo-doo. The only thing I can think to do is pull the whole engine out & take the transmission off. That's way beyond my experience level, so I'll have to marshal some help from a few buddies. Any suggestions? Link to comment Share on other sites More sharing options...
Reuben Posted July 1, 2010 Share Posted July 1, 2010 You will need: Massive screw driver. Access hole in the bell housing. Hole in the flex plate. Insert screwdriver through the holes in the flex plate, and the bellhousing. Done. If it's a manual, put a bolt inbetween the bell housing and the teeth on the flywheel. Done. Link to comment Share on other sites More sharing options...
WilliamMunny Posted July 2, 2010 Share Posted July 2, 2010 I use a chain tool with a piece of rubber hose over the chain and a breaker bar on the pulley. Harbor freight chain tool was like $12 and I use it all the time. Link to comment Share on other sites More sharing options...
BennnGeee Posted July 2, 2010 Share Posted July 2, 2010 A pulley remover is the safest way and it only cost about 14 bucks. Link to comment Share on other sites More sharing options...
Reuben Posted July 3, 2010 Share Posted July 3, 2010 A pulley remover is the safest way and it only cost about 14 bucks. They cost like $60-$100 for some f***ed up un-known reason. That's straight from subaru japan though, never seen an aftermarket on... Link to comment Share on other sites More sharing options...
trevorno Posted July 3, 2010 Share Posted July 3, 2010 Large screwdriver through the bell housing access port worked great. Once I got the bolt out, I tapped on the pulley with a hammer and pit came right out. The only issue was holding the pulley in place to break the bolt. I'm going to try a strap wrench to get the camshaft pulleys off. Link to comment Share on other sites More sharing options...
WilliamMunny Posted July 3, 2010 Share Posted July 3, 2010 anyone do the starter technique? Seems like a horrible idea but I've heard its safe if you know what you're doing. Link to comment Share on other sites More sharing options...
