KyLegacy 2.5GT Posted January 5, 2010 Share Posted January 5, 2010 Hey guys, I've tried searching the forums for locations of where people tied in their transmission temperature gauges and couldn't find anything. I currently have a tranny cooler installed and was thinking about putting the sensor in line before it goes back into the tranny. I really don't want to pull down my pan and drill into it for this sensor. Are there any other locations that would be better suitable? I made up a brass T that has barbed fitting on the two opposing ends and the the last opening has the sensor fitted to it. This way I can tap into any of the flexible tranny fluid lines. Please let me know your thoughts or if you can find any other threads.Thanks! *Can one of the MODs change the title to say 'Gauge' instead of 'Guage'?* Link to comment Share on other sites More sharing options...
fishbone Posted January 5, 2010 Share Posted January 5, 2010 Best location is in the ATF drain bolt. You replace the bolt with one that can accomodate the sender unit. Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted January 5, 2010 Author Share Posted January 5, 2010 Do you remember where you got your drain bolt from?? Size?? Link to comment Share on other sites More sharing options...
fishbone Posted January 6, 2010 Share Posted January 6, 2010 I have yet to get one, but what you need is M18x1.5 Link to comment Share on other sites More sharing options...
KyLegacy 2.5GT Posted January 6, 2010 Author Share Posted January 6, 2010 Yeah, no luck finding one. I would need a M18x1.5 with a 1/8"NPT hole through the center. Autometer supplies two with the kit, but they are standard size plugs. I looked at McMaster Carr, Google, Napa, Summit, etc, and still can't find anything similar. I may just have to stick with the T fitting I made for now unless anybody else knows on a plug that would work. Link to comment Share on other sites More sharing options...
fishbone Posted January 6, 2010 Share Posted January 6, 2010 Unless I am mistaken, ClimberD was able to either get one or find one on eBay from a seller in UK? Link to comment Share on other sites More sharing options...
