TGV deletes
fullerslgt
Theoretically the larger phenolic spacer will improve performance, not considering here the affect of lengthening your intake runners. I read, though, that the taller units should be used if you have front mount intercooler. I must assume then that the extra 5-8mm interferes with the TMIC
Maybe it depends where the FMIC tubes run, but I have an AVO FMIC and 8mm spacers, and no clearance issues.
However I don't think I can fit the engine cover anymore. Haven't tried though. :)
  • 1 year later...
What tgvs will fit the 05 manifold but convert to top feed rails?
I want top feed injectors but i really want 1300cc injectors meaning i'd be going DW and T1 says they won't fit their top feed conversion kit.
Thank you,
Bill
