700watts Posted January 5, 2010 Share Posted January 5, 2010 My baby hit a curb a while back, and the body shop replaced the strut. Ever since then the car still pulls to the right and it seems that the strut is "soft". Meaning that when I make a right turn, it rides on rails. When I make a left turn, It feels like it's roles more to the right "soft strut", more like down-right sloppy. My question is, could they have put a regular legacy strut in, not a "LGT" and or an aftermarket strut? If so, how can I tell ? Link to comment Share on other sites More sharing options...
RJS5689 Posted January 5, 2010 Share Posted January 5, 2010 I thought the USDM Legacy N/A models and Legacy GT used the same KYB struts? Link to comment Share on other sites More sharing options...
700watts Posted January 5, 2010 Author Share Posted January 5, 2010 If that's the case...then there's diffidently something wrong Link to comment Share on other sites More sharing options...
timmahh Posted January 5, 2010 Share Posted January 5, 2010 Maybe your other shocks need to be replaced? How many miles do you have on it? Link to comment Share on other sites More sharing options...
700watts Posted January 5, 2010 Author Share Posted January 5, 2010 64k not that much Link to comment Share on other sites More sharing options...
schwinn Posted January 6, 2010 Share Posted January 6, 2010 Stock springs? Any other mods to the suspension? The stock struts very well could be worn in 64k miles... particularly if you drive the car hard or heavily loaded. Link to comment Share on other sites More sharing options...
700watts Posted January 6, 2010 Author Share Posted January 6, 2010 correct me if I'm wrong but, if the other struts and springs are worn. then shouldn't the car handle like crap when turning "right", and better when turning "left". But if feels like the strut replaced is "mushy". could a bad strut go stiff ? Link to comment Share on other sites More sharing options...
CardinalFJ60 Posted January 6, 2010 Share Posted January 6, 2010 sounds like there is another issue that may be contirbuting to your handling concerns. I'd check what the alignment issue is and determine if the camber or toe is affecting your handling (i.e. pulling to the right). for example, if your camber is off, perhaps your one tire might be 'rolling' over too far during the turn or something. Link to comment Share on other sites More sharing options...
700watts Posted January 6, 2010 Author Share Posted January 6, 2010 sounds like there is another issue that may be contirbuting to your handling concerns. I'd check what the alignment issue is and determine if the camber or toe is affecting your handling (i.e. pulling to the right). for example, if your camber is off, perhaps your one tire might be 'rolling' over too far during the turn or something. Agreed, it's back in the shop... Link to comment Share on other sites More sharing options...
OldToot Posted January 6, 2010 Share Posted January 6, 2010 I was always told you had to replace shocks in pairs, regardless of mileage. Link to comment Share on other sites More sharing options...
700watts Posted January 6, 2010 Author Share Posted January 6, 2010 ^ That would make too much since ...... Link to comment Share on other sites More sharing options...
schwinn Posted January 7, 2010 Share Posted January 7, 2010 correct me if I'm wrong but, if the other struts and springs are worn. then shouldn't the car handle like crap when turning "right", and better when turning "left". But if feels like the strut replaced is "mushy". could a bad strut go stiff ?Certainly... struts may not wear out the same way, or at the same time, or to the same degree. But, beyond that, the replacement could be bad, suffered an infant-mortality failure, been damaged during installation, installed improperly, or the wrong part... And, as Cardinal mentioned, it could all be compounded with alignment and other issues. Replacing all your shocks and getting the alignment check might be a good "shotgun" idea to resolve this. Link to comment Share on other sites More sharing options...
BN2 Posted January 8, 2010 Share Posted January 8, 2010 my money is on psychology.. or a bent something... Link to comment Share on other sites More sharing options...
CardinalFJ60 Posted January 8, 2010 Share Posted January 8, 2010 Agreed, it's back in the shop... Any update on this? I'm curious about the resolution. (my LGT is doing the same thing) Link to comment Share on other sites More sharing options...
