jcdub100 Posted January 4, 2010 Share Posted January 4, 2010 Hey guys, I am pretty new to the forums here, I was wondering if you can help me. I have a Subaru Legacy L '93 that I recently changed the timing belt on but after putting it back together with the marks all facing up and tried to start it.... but it just cranks and won't start up. The only thing that I got was some smoke coming from the intake. After cranking a second time the two side pulleys are facing down and the middle one is facing up. I don't know what the problem can be, any ideas? Thanks Link to comment Share on other sites More sharing options...
Bdubs Posted January 5, 2010 Share Posted January 5, 2010 You didn't line the belt up to the ARROWS on the cam sprockets did you? There are small hash marks on the outer rings to designate timing. Also, the timing mark is on the back of the crank sprocket, like this:http://www.main.experiencetherave.com/subaru/images/timingbelt/DCP_2728.JPG The arrows are to determine where TDC is on piston #1. Link to comment Share on other sites More sharing options...
jcdub100 Posted January 5, 2010 Author Share Posted January 5, 2010 Omg thank you very very much!! i didn't see the the line up mark on the middle sprocket! i aligned it up and now my car is running ..thank you again you were BIG help...tnx:) Link to comment Share on other sites More sharing options...
