HID Install Oddity
FJ60
Low beams work fine.
Low beams with fogs work fine.
ONLY passenger side low/hi work when hi beams are activated -- switched hi beam bulbs, same result.
ONLY passenger side low/hi work when either hi beam bulb is pulled from its harness during low beam.
Wiring double and triple checked by two knowledgeable people. All fuses checked. Clean ground contacts verified.
WTF? Any ideas out there?
[FONT=Comic Sans MS][B][I]"Sweep the leg!" - Sensei Kreese, Karate Kid [/I][/B][/FONT]
You rock, leglover! We were wasting our time checking the fuses connected to the relays. The first underhood fuse I checked -- bingo!
THANK YOU!
