NSFW Posted December 26, 2009 Share Posted December 26, 2009 I want this clutch... http://www.clutchmasters.com/shop/?page=shop%2Fflypage&MakeID=29&FromYear=2007&MakeModelID=160&AppID=2557 ...but they only list it for 07+ LGTs. Anyone know what changed between 06 and 07? Can my 05 be converted to fit that clutch/fly/pp kit? Thanks! Link to comment Share on other sites More sharing options...
Bolksey85 Posted December 26, 2009 Share Posted December 26, 2009 I'm pretty sure the 05-06 had the dual mass flywheel and in 07 went to a single mass. Link to comment Share on other sites More sharing options...
NSFW Posted December 26, 2009 Author Share Posted December 26, 2009 Interesting. That kit includes a new flywheel. Does that mean there's hope? Don't the ACT kits work for 05-09? Link to comment Share on other sites More sharing options...
SubyShop.com Posted December 26, 2009 Share Posted December 26, 2009 05-06 can be converted to the 07+ with a new single mass flywheel and the corresponding clutch kit and pressure plate. Basically Subaru made the LGT the same style as 06+ WRX for the 07+ LGT MY. That clutch kit is very expensive.. what makes you prefer that over an ACT street setup? -Franz Link to comment Share on other sites More sharing options...
NSFW Posted December 26, 2009 Author Share Posted December 26, 2009 05-06 can be converted to the 07+ with a new single mass flywheel and the corresponding clutch kit and pressure plate. Basically Subaru made the LGT the same style as 06+ WRX for the 07+ LGT MY. That clutch kit is very expensive.. what makes you prefer that over an ACT street setup? -Franz Thanks for the info. Part of the reason it's so expensive is that it includes everything (clutch, pressure plate, flywheel) but most of the reason is that's the MSRP, not the street price. I think I can get it all for about $1000, but I'm still investigating. That's a bit more expensive than similar parts from ACT, but it should be a bit stronger too. Since the kit includes everything (clutch, pp, fly), it should just fit, right? Or is there something I'm overlooking? It's my 52 lb/min turbo that makes me not want the ACT street setup. Here's a post from j255c, who got the ACT street clutch to slip with a 44 lb/min turbo on meth: http://legacygt.com/forums/showthread.php?p=2742277 ...my turbo on straight pump gas probably makes similar torque. Clutchmasters claims more torque for this kit than ACT does for theirs. That's no guarantee, but I'm hoping to avoid going to a pucked or multi-disk clutch and I figure the odds are better with this one than with ACT. Link to comment Share on other sites More sharing options...
Bolksey85 Posted December 26, 2009 Share Posted December 26, 2009 I've heard a lot of positives on Clutch Masters. ACT will get a not so good review here and there but CM and Spec seem to be always positive. Link to comment Share on other sites More sharing options...
NSFW Posted December 26, 2009 Author Share Posted December 26, 2009 I've read just as much bad feedback as good for Spec, and some of it has been horrible enough to steer me away from that brand. This was the last straw for me: http://legacygt.com/forums/showpost.php?p=1595639&postcount=2 Link to comment Share on other sites More sharing options...
theotly09 Posted December 27, 2009 Share Posted December 27, 2009 oh, also... what about the clutch pedal assembly and clutch cable. Do you guys know of which parts to use and any instructiosn for the install? Thanks. Link to comment Share on other sites More sharing options...
