Bostonian1976 Posted December 25, 2009 Share Posted December 25, 2009 I know I've read in the past that the cruise control module is by the right wheel on my 98 Legacy...but I don't know where now. I'm trying to figure out why it's not working, and want to check the vacuum line. Any help would be appreciated - thanks! Link to comment Share on other sites More sharing options...
Bostonian1976 Posted December 27, 2009 Author Share Posted December 27, 2009 anyone? Link to comment Share on other sites More sharing options...
SBT Posted December 27, 2009 Share Posted December 27, 2009 Just look for a black, plastic 4" round-shaped (possibly with a "cone-shaped" end) piece that has a hard, black, 1/4" thick cable coming out of it and going to the throttle body. Cable should loop along the firewall and then go into the throttle body. I'll see if I can find a view of it from my FSM. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
SBT Posted December 27, 2009 Share Posted December 27, 2009 Here's a couple of pics with the module shown. 1st is a 2.5L DOHC and the 2nd is a 2.2L SOHC. Both modules are on 98 Subaru Legacys. HTH - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
Bostonian1976 Posted December 29, 2009 Author Share Posted December 29, 2009 very helpful thank you! so nothing by the right wheel? I could have sworn I remember that...hmm Link to comment Share on other sites More sharing options...
987687 Posted January 2, 2010 Share Posted January 2, 2010 That second pic is an RHD car, and it is the same place as the LHD car even. Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2010 Share Posted January 2, 2010 Correct! The FSMs have them in the same place for all the BDs. Typically don't seem them moved unless the owner needs the firewall space for something else. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
987687 Posted January 2, 2010 Share Posted January 2, 2010 even if it is somewhere random. There are 2 cables to the throttle body, one is thicker and goes into the firewall to the gas pedal. The other is thinner and goes to the CC unit. So follow it to wherever that unit may be hiding. Link to comment Share on other sites More sharing options...
ehsnils Posted January 2, 2010 Share Posted January 2, 2010 And if there is only one cable your car may lack the cruise control. It may have been removed earlier for some reason, or it may never have been there. And if you have a lever for the cruise control in the car it may be that it was added later by someone planning to install the cruise control but then aborted the project. Link to comment Share on other sites More sharing options...
SBT Posted January 2, 2010 Share Posted January 2, 2010 ... And if you have a lever for the cruise control in the car it may be that it was added later by someone planning to install the cruise control but then aborted the project. Or just changed out the steering wheel from a CC Subaru and left the CC switch on it. I've actually seen that on a Impreza Brighton. - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
DN1911 Posted May 5, 2011 Share Posted May 5, 2011 the module is under the dash somewhere with about 20 wires coming out of it. the picture is pointing out the cruise control motor that physicaly drives the throttle body. there is also a cruise control pump that is usually on the passenger fender by the AC dryer with a vacuum tube going up to the motor Link to comment Share on other sites More sharing options...
TbirdMan Posted May 6, 2011 Share Posted May 6, 2011 One other thing, if it is like my Impreza, the CC lever power actually runs through the horn relay. if the relay goes out the CC won't work, the light on the button on the dash will come on but the lever won't set it. Link to comment Share on other sites More sharing options...
