Slozenger Posted December 24, 2009 Share Posted December 24, 2009 Hello guys. I recently purchased a 1993 Subaru Legacy Station Wagon. The window has a problem. While it does move up an down, it only pushes up from the back of the window. It seems the front part is not driven at all, you need to push up with your hand at the same time!!! Having had a quick look (taken outer panel off) it seems of the 3 runners, the front is not working. Now, looking at the inner workings of the door, we are a little stumped. The rubber seal seems quite hard to remove, i'm worried I won't be able to get it back on! How should we go about removing the metal panel? How should we go about re-attaching the door? etc etc etc. Thankyou in advance, and MERRY CHRISTMAS! ---------- TL: DR.. Tell me about Subi Doors! Link to comment Share on other sites More sharing options...
