Baddog Posted December 23, 2009 Share Posted December 23, 2009 I have a broken wheel stud on my left front hub. I looked up how to do it. And it just seems extremely easy. Is it truly this easy to do? Hammer out the old one. Slide the new one through put a couple nuts on there and use an impact gun to pull it through? Link to comment Share on other sites More sharing options...
Impulse Posted December 23, 2009 Share Posted December 23, 2009 either an impact gun (the type designed to put on nuts, the ones where you pull out) or just put the wheel on normally and tighten. i usually use a nut to pull the new stud through enough so its snug enough to fit on a wheel then put the nut on normally through the wheel. Link to comment Share on other sites More sharing options...
amp27 Posted December 23, 2009 Share Posted December 23, 2009 they dont just slide in or out? i thought mine were just rusted in. live and learn Link to comment Share on other sites More sharing options...
Baddog Posted December 23, 2009 Author Share Posted December 23, 2009 Well I don't mean slide. I mean just place there and pull through with a nut on the other end and impact gun it to pull the stud through. Link to comment Share on other sites More sharing options...
jvento Posted December 23, 2009 Share Posted December 23, 2009 mine where rusted too.... Link to comment Share on other sites More sharing options...
amp27 Posted December 23, 2009 Share Posted December 23, 2009 rust. my cv axle was rusted into the hub. took awhile to change a cv shaft. Link to comment Share on other sites More sharing options...
