ScoobyDoo42 Posted December 21, 2009 Share Posted December 21, 2009 So I noticed a lot of whining from the front diff and the trans shifts pretty hard but when its cold out it seems to have a little struggle to shift. Was wondering what all i need to swap the Auto out of my 96 and do a manual swap in to it. What all do I need? (I mean obviously I need trans, rear diff, axles, driveshaft clutch pedal, slave and master cylinder) but what else do I need? Is there wiring involved? will it be hell to do? I am looking in to this a lot and just wanna know what all i need. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
amp27 Posted December 21, 2009 Share Posted December 21, 2009 +1 Link to comment Share on other sites More sharing options...
987687 Posted December 21, 2009 Share Posted December 21, 2009 It has been discussed a lot before. So some searching will bring up some data. But to put it bluntly, it is a PITA. Get a manual. Other than that ... sure it is possible. The 1996 tranny is a clutch cable, so you don't need the hydraulic setup, unless you get a newer tranny. things you'll need: clutch pedal brake pedal rear diff tranny axles driveshaft tranny cross member clutch/flywheel kit cut a hole for the shifter play with the wiring and ECU (I'm pretty sure you can use the same ECU...) all sorts of other stupid parts you wouldn't realize you need until you are half-done. Would be best to get a manual donor car and do the swap from that. That way when you need that stupid part you'll have it. I say not worth it, but if you are in for a project, go ahead. It's been done Link to comment Share on other sites More sharing options...
WESTcoast Posted December 22, 2009 Share Posted December 22, 2009 ^ YUP what they said, its a big pain for us Link to comment Share on other sites More sharing options...
ScoobyDoo42 Posted December 22, 2009 Author Share Posted December 22, 2009 Well poop!!! That blows Link to comment Share on other sites More sharing options...
WESTcoast Posted December 22, 2009 Share Posted December 22, 2009 yeah sorry to bust your bubble like that, but hey look on the bright side you can shift with no hands!!!!! Link to comment Share on other sites More sharing options...
ScoobyDoo42 Posted December 22, 2009 Author Share Posted December 22, 2009 Hahaha it's okay my friend! And I know. Hopefully the trans holds for a long time Link to comment Share on other sites More sharing options...
amp27 Posted December 23, 2009 Share Posted December 23, 2009 they make a manual shift kit for the 4eat. its just a bunch of electron its the control the tranny. Link to comment Share on other sites More sharing options...
