Laughngethigh Posted December 17, 2009 Share Posted December 17, 2009 I think Im idling too high. What is it supposed to be? Link to comment Share on other sites More sharing options...
Laughngethigh Posted December 17, 2009 Author Share Posted December 17, 2009 Update. Check engine light came on and now when I turn the fan on for my thermostat its alot louder than normal. Going get it coded tommorow. Link to comment Share on other sites More sharing options...
Laughngethigh Posted December 17, 2009 Author Share Posted December 17, 2009 *update* Got it coded.... "P0505" - IAC circuit or idle speed higher/lower than expected (The ECM has detected that the IAC counts are higher or lower than expected, the engine speed is not in its expected range.) Probable cause - Vacuum leak on engine Dirty Throttle body IAC motor defective Poor electrical connection to the IACV "P0507" - Idle control system RPM higher than expected Probable cause - Large vacuum leak Throttle linkage concern Faulty IACV TPS signal faulty What should I do myself before spending the big bucks at the dealership? Link to comment Share on other sites More sharing options...
98quiksilvergt Posted December 20, 2009 Share Posted December 20, 2009 You can back the idle screw out a little. I had the same code and that fixed my problem. It's on the lower drivers side of the t-body. Link to comment Share on other sites More sharing options...
Laughngethigh Posted December 21, 2009 Author Share Posted December 21, 2009 Whenever I first turn the car on it idles high, and whenever its been warmed up it idles low. After driving around for a while, the check engine light goes off. Cant explain this one. I scheduled an appointment at my local Subaru dealership. Link to comment Share on other sites More sharing options...
vermont22gt Posted December 21, 2009 Share Posted December 21, 2009 You can back the idle screw out a little. I had the same code and that fixed my problem. It's on the lower drivers side of the t-body. Personally, I'd stay away from the idle screw. You got a CEL for IAC circuit. Start there. Remove IAC, spray out the mechanical portion with carb cleaner, new gasket, replace. It's worked for me, it may work for you. Link to comment Share on other sites More sharing options...
987687 Posted December 22, 2009 Share Posted December 22, 2009 +1 that ^ the idle screw fix is trying to cover up for a bigger problem. It will cause more issues in the long run. Link to comment Share on other sites More sharing options...
Laughngethigh Posted December 23, 2009 Author Share Posted December 23, 2009 Thanks guys. But Im going to let the dealership handle it because I also believe I never got the recalled Camshaft/crankshaft sensors replaced...might as well. Link to comment Share on other sites More sharing options...
amp27 Posted December 23, 2009 Share Posted December 23, 2009 so is 500 rpm to low. for idle. is this a problem in the mist and should be fixed. i like it though. it bonces from 400 to 700. and its sleath. Link to comment Share on other sites More sharing options...
987687 Posted December 23, 2009 Share Posted December 23, 2009 Don't go by what the gauge says, it isn't terribly accurate always. Going by my scangauge2 my car idles at 700 +/- 20 RPMs once warmed up. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted December 23, 2009 Share Posted December 23, 2009 What iac? I don't see one? Just a tps. My car idled fine before my headgaskets were replaced. We cleaned a crapload of carbon out of everywhere so, I thought it was idling high because there was more flow. That's why I backed the screw out a couple threads. It was sitting around 1400 when cold and 1100 warmed up. It's been fine but were is that iac. If there's a problem with that I'd like to fix it. I don't like to cut corners. Link to comment Share on other sites More sharing options...
98quiksilvergt Posted December 23, 2009 Share Posted December 23, 2009 Oh, I got my idle at 700 warm. Link to comment Share on other sites More sharing options...
