timmahh Posted December 15, 2009 Share Posted December 15, 2009 I bought a SPEC Stage 2 clutch from a member on here - two quick questions: 1) TSK-3 Kit needed? [or, better question - not needed, but good to do?] 2) Do I need to use the OEM DMFW or can I use the 06+ WRX SMFW ? Link to comment Share on other sites More sharing options...
1astrokeit Posted December 16, 2009 Share Posted December 16, 2009 i dont think the spec clutch will mate with the wrx flywheel since the clutch is for a legacy flywheel. but im not sure on that on. i think you need a wrx clutch to mate correctly. everyone with the tsk4 kit loves it. i bought mine but havent did the clutch change yet so i cant tell you personally Link to comment Share on other sites More sharing options...
Zeus Posted December 16, 2009 Share Posted December 16, 2009 See if it will fit the 07+ single mass GT flywheel... I don't know, but have an 07+ GT PP/disc/single mass flywheel coming to install this weekend. Link to comment Share on other sites More sharing options...
timmahh Posted December 17, 2009 Author Share Posted December 17, 2009 I guess i'll be getting the stock DMFW since the clutch I bought is for an 05 LGT.. Link to comment Share on other sites More sharing options...
1astrokeit Posted December 17, 2009 Share Posted December 17, 2009 u might be able to get a 07 legacy flywheel but im not sure if the clutch is same part number Link to comment Share on other sites More sharing options...
timmahh Posted December 17, 2009 Author Share Posted December 17, 2009 I sent an email to SPEC asking if it's the same clutch for 05 - 06 and 07 - 09 Link to comment Share on other sites More sharing options...
GTTuner Posted December 17, 2009 Share Posted December 17, 2009 I sent an email to SPEC asking if it's the same clutch for 05 - 06 and 07 - 09 If it is then it wont work with the DM flywheel. Link to comment Share on other sites More sharing options...
