Do these headlights look aligned?
veritas
Ok, so I was finally able to snap some pics of my lights on so if the informed people can take a look and tell me if these look ok. I hope the pics are good enough.
Here we go:
5 Feet:
http://i34.photobucket.com/albums/d113/climbinglife/IMG_1746.jpg
10 Feet:
http://i34.photobucket.com/albums/d113/climbinglife/IMG_1753.jpg
10 Feet With High Beams on:
http://i34.photobucket.com/albums/d113/climbinglife/IMG_1754.jpg
25 Feet:
http://i34.photobucket.com/albums/d113/climbinglife/IMG_1758.jpg
25 Feet with high beams on:
http://i34.photobucket.com/albums/d113/climbinglife/IMG_1759.jpg
I hope these are enough.
Thanks for any help,
Vin C
NYC
^ The guru has spoken! :) You're good to go!
OK, now that that's settled, what's up with the high-beams?!!?!!!!
<-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges
'16 Outback, '16 WRX, 7th Subaru Family
Thanks for the help guys. I guess I just never noticed the line before...as for the high beams, I'm putting my stock ones back in. I bought a set of blue-ish bulbs from Pep boys and I guess they suck.
As far as the third shot. the ground was pretty level. could have been the angle I was holding the camera at. You think they need to be adjusted down slightly?
if the ground is level then based on the 3rd shot you are high on the aim. Follow my aiming guide when you find more level ground and you should be all set. The DOT approved drop rate is that your low section of the beam should drop ~ 2 inchs at a distance of 25ft from the stock height of the projector. The high beams are aimed fine as that's how they look but this car's highs aren't that great anyways so don't worry about them.
The driver side of the driver side low-beam should be aligned level with the driver side of the passenger side low-beam. I.e., the headlights should be level with one another.
06LOB2.5i MT, JDMRSB, GYTTs, HPS, LGT Mufflers & Leather Wheel, SubiMomo Knob, Inalfa Moonroof, Clutch Switch Bypass, DeDRLd, DeChimed, & Straight Headrest.
The driver side should be lower so you don't blind incoming traffic. I.e. Both sides should not have the same vertical cutoff such as in your photos.
You are wrong my friend. The low beams lower step should be aligned with one another leaving the high step for distance and signs. The correct distance for DOT specs is 2 inches lower than the projector height at 25ft.
When you talk like that it makes me all tingly inside! :spin:
