Bostonian1976 Posted December 12, 2009 Share Posted December 12, 2009 Does your gas light come on when you start your car? I have yet to ever see mine, and want to make sure it works. thanks!! Link to comment Share on other sites More sharing options...
Bostonian1976 Posted December 12, 2009 Author Share Posted December 12, 2009 low fuel, that is Link to comment Share on other sites More sharing options...
Bdubs Posted December 12, 2009 Share Posted December 12, 2009 It comes on only when the sensor on the fuel pump gets to a certain point. It doesn't come on with the other lights as you first start the car. Link to comment Share on other sites More sharing options...
987687 Posted December 14, 2009 Share Posted December 14, 2009 For me, it comes on with just over 2 gal left. I can get around 70 miles with my gas light on before I run out ... PS, I had a spare tank of gas with me when I found that out. *PHEW* Link to comment Share on other sites More sharing options...
datdookie Posted December 14, 2009 Share Posted December 14, 2009 Mine never comes on even when under the line of "E". Is there a way to fix that? Link to comment Share on other sites More sharing options...
987687 Posted December 14, 2009 Share Posted December 14, 2009 When my gauge goes under E I have quite a while before the gas light comes on. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted December 17, 2009 Share Posted December 17, 2009 Yeah. Its aways below the E. But I think my fuel pump is bad. Never never ever run it out of gas. I will burn up the Fuel Pump. No gas is bad all around for the pump. It will overheat. Just keep that in mind. Link to comment Share on other sites More sharing options...
Bostonian1976 Posted December 18, 2009 Author Share Posted December 18, 2009 what a warped system. I get too nervous even being close to E. I guess I'll never see mine Link to comment Share on other sites More sharing options...
987687 Posted December 18, 2009 Share Posted December 18, 2009 Mine came on today for a few miles. Then went off again. I'll probably fill up in the next couple days sometime. Can go quite a long way on gas light. Link to comment Share on other sites More sharing options...
ESSYMOND Posted December 22, 2009 Share Posted December 22, 2009 My gas light broke or just doesn't come on even when my car ran out of gas and sat there on the road. Any suggestions to fix? could it be the bulb blown? Link to comment Share on other sites More sharing options...
cman7 Posted December 22, 2009 Share Posted December 22, 2009 http://i87.photobucket.com/albums/k148/coreboy7/suby/04-08-09_1600.jpg Yeah. I've heard this a thousand times. The gas light comes on at different times. Sometimes its just under the E and sometimes its quite a bit under the E. Link to comment Share on other sites More sharing options...
987687 Posted December 22, 2009 Share Posted December 22, 2009 http://i190.photobucket.com/albums/z314/987687/car/IMG_2405.jpg Link to comment Share on other sites More sharing options...
streetlethal1000 Posted December 22, 2009 Share Posted December 22, 2009 So it really does have a gas light. I have never seen mine either. I would always go to E and refill and just thought they didnt put one in this car for one reason or another. Ill have to try running it down with spare gas in the back just to see. I am curious now. Link to comment Share on other sites More sharing options...
987687 Posted December 23, 2009 Share Posted December 23, 2009 When you are filling it up from E, how much are you putting in? You have a 15.9gal tank. Link to comment Share on other sites More sharing options...
Bostonian1976 Posted December 24, 2009 Author Share Posted December 24, 2009 http://i190.photobucket.com/albums/z314/987687/car/IMG_2405.jpg better put some gas in there to make it to 100K Link to comment Share on other sites More sharing options...
WESTcoast Posted December 24, 2009 Share Posted December 24, 2009 I once tested that theory to see how much a 10 bucks would get me unfortulently I was fearless and courageous enough to actually run out of gas and was on the side of the road.......oh and doing that i successfully concluded that my gas light does in fact work. Link to comment Share on other sites More sharing options...
