SSpeed Posted November 29, 2009 Share Posted November 29, 2009 '98 Outback SOHC 2.5L Just bought the car, has burned valves on one cylinder. How do you remove the plastic cam gears so the head can come off? The service manual talks about a special tool, but I'm sure there are other ways? Link to comment Share on other sites More sharing options...
Bdubs Posted November 29, 2009 Share Posted November 29, 2009 I always use an interior trim removal tool which is basically a light duty prybar. Gently work your way around it, or two at the same time on opposite sides of each other, and it'll work its way out. Just be careful not to damage the sensors on the cam gears. Link to comment Share on other sites More sharing options...
SSpeed Posted November 30, 2009 Author Share Posted November 30, 2009 Let me go one step back... how do you get the bolts off of the cam gear to get it to the point where gently work your way around it? Link to comment Share on other sites More sharing options...
SSpeed Posted November 30, 2009 Author Share Posted November 30, 2009 Also, I was looking at the factory service manual, do you really need to pull the cams to get the head off? They don't come off as one assembly? Link to comment Share on other sites More sharing options...
Bdubs Posted December 1, 2009 Share Posted December 1, 2009 Let me go one step back... how do you get the bolts off of the cam gear to get it to the point where gently work your way around it? Ah! Yes, where the "special tool" is required. You really want to use that, because you don't want the cams to move as you remove the gears. Some dealers will just let you borrow it, if you can convince them you'll bring it back. Also, you'll have to pull the cams to get the back timing belt cover off, because there are bolts holding it to the block AND the head. Link to comment Share on other sites More sharing options...
SSpeed Posted December 1, 2009 Author Share Posted December 1, 2009 Wow, a dealer will let me borrow the tool? So there aren't any wrench spots on the cam like some cars? I'm beginning to think it may be easier to simply pull the engine to do it.... Link to comment Share on other sites More sharing options...
