Tinman Posted November 19, 2009 Share Posted November 19, 2009 I am a newbie when it comes to audio installation. I am reusing the factory speaker wires to save me time pulling new wires through the car. I have a popping noise after I connected the wires. (Alpine 600 components) What could I have done wrong? Any help would be appreciated. Thanks in advance. Oops, never mind. My bad. I fixed it. Link to comment Share on other sites More sharing options...
markc0220k Posted November 20, 2009 Share Posted November 20, 2009 so, what was it? : ) Link to comment Share on other sites More sharing options...
Tinman Posted November 20, 2009 Author Share Posted November 20, 2009 I was using the existing wires to the tweeter. I capped those off and it sounds fine. Learning on the fly. I've never done a stereo install before. I am done with the speakers, next up is the amp, sub, and MTX Re-q5. I need to go to Home Depot and buy some 3/4" MDF for the rack. I have everything else. I am going to put the rack in above the spare tire. Link to comment Share on other sites More sharing options...
markc0220k Posted November 20, 2009 Share Posted November 20, 2009 oh? those apline spk are fit in? no need spacer? your ReQ5 will be on the rack? how can you tight it down? pls let me know, i'm thinking to do what you are doing. thanks Tinman. Link to comment Share on other sites More sharing options...
markc0220k Posted November 21, 2009 Share Posted November 21, 2009 i just installed (just driver's side) a front spk. yes, no need spacer. gap is about 4+inches (almost 5). took a lot of pics. the most hardest part should be feeding a wire from the door to the body... Link to comment Share on other sites More sharing options...
