finboy Posted November 19, 2009 Share Posted November 19, 2009 Anything to be aware about for a sway swap (front and rear) -tricks? watch out for...... do this first, remove this?? and how much time for each? Link to comment Share on other sites More sharing options...
turboman38 Posted November 19, 2009 Share Posted November 19, 2009 Take driver side muffler off to install the rear. If you have the additional brackets (Depends on manufacturer of the sway bar) for the rear sway bar use them. Take your time when reinstalling the bolts. I cross threaded one in the rear and one in the front. Link to comment Share on other sites More sharing options...
Darkness of Death Posted November 19, 2009 Share Posted November 19, 2009 dont forget about reinforced brackets for the rear end. the front would probably require you to take some more things off (engine cross member??)..i'm not too definite as i had a bunch of things done at the same time as the front sway bar Link to comment Share on other sites More sharing options...
