FireB Posted November 19, 2009 Author Share Posted November 19, 2009 Light acceleration meaning pretty much up to 0 psi or lower in the vacuum range correct? I do most of my driving even without hitting boost. When I go places on the weekends using the highway, that would be the time I would be under boost. I don't flat foot the pedal and gradual acceleration on the gas is my thing so I am sure I should be hitting it but....... Either way, I will keep updating with more logs! Thanks! Link to comment Share on other sites More sharing options...
CasopoliS Posted November 19, 2009 Share Posted November 19, 2009 If you are familiar with modifying maps, you could temporarily change A/F Learning C to 50-60 and D to 60+ which might provide more valuable data just prior to going into CL. This helps a little with MAF scaling. Link to comment Share on other sites More sharing options...
FireB Posted November 19, 2009 Author Share Posted November 19, 2009 If you are familiar with modifying maps, you could temporarily change A/F Learning C to 50-60 and D to 60+ which might provide more valuable data just prior to going into CL. This helps a little with MAF scaling. Nice, I don't know too much about it as I am on the learning stage. However, I'll take notes so that maybe a little later I might know what I am doing and take your advise! I will ask for the new map from Infamous probably tomorrow to see what can be done. Link to comment Share on other sites More sharing options...
FireB Posted November 20, 2009 Author Share Posted November 20, 2009 OKie I tried to do a log and connected the LC-1 to the USB but getting nothing out of it. I tried all the ports and refreshed each time for like 5 times straight but nothing is going on. Do they have some kind of Driver associated with this kit? Even when I try to open up "LogWorks3", it still does not recognize. Does that mean I have a bad connection before the USB? I bought a brand new Serial to USB and it seems like the LED is telling me that it is connected. I am using the "OUT" BlackCable and not the "IN" Black cable that comes with the LC-1. Let me know if that is correct also. Any thoughts? Thanks! Link to comment Share on other sites More sharing options...
CasopoliS Posted November 20, 2009 Share Posted November 20, 2009 OKie I tried to do a log and connected the LC-1 to the USB but getting nothing out of it. I tried all the ports and refreshed each time for like 5 times straight but nothing is going on. Do they have some kind of Driver associated with this kit? Even when I try to open up "LogWorks3", it still does not recognize. Does that mean I have a bad connection before the USB? I bought a brand new Serial to USB and it seems like the LED is telling me that it is connected. I am using the "OUT" BlackCable and not the "IN" Black cable that comes with the LC-1. Let me know if that is correct also. Any thoughts? Thanks! Did you put the other plug in the IN connection? Its a little stub plug provided. Then you put the Serial cable into the out. Link to comment Share on other sites More sharing options...
FireB Posted November 20, 2009 Author Share Posted November 20, 2009 Did you put the other plug in the IN connection? Its a little stub plug provided. Then you put the Serial cable into the out. Yes I did, it was almost like an end cap with the stereo plug on it right? I have the OUT wires connected to the Serial to the USB. Maybe it might be the Serial to the USB problem...... ughh, I just can't win... Link to comment Share on other sites More sharing options...
