chitty chitty bang bang Posted November 18, 2009 Share Posted November 18, 2009 Recently I've noticed that my car idles when starting at about 1600 - if I wait in the car for 2-3 minutes for it to warm, the car will stay at 1600. If I blip the motor, the car will come back down to 8-900 - what is happening? I've checked the idle set screw, and even lubed the throttle body where the pedal cable and cruise cable attach - what's going on? Link to comment Share on other sites More sharing options...
subikid90 Posted November 19, 2009 Share Posted November 19, 2009 I have the same problem with my 98gt. Ive been told its just the choke? Im not positive and haven't spend much time looking into it tho. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
aim Posted November 19, 2009 Share Posted November 19, 2009 It does sound like the choke. Is it running rich while on higher revs? Link to comment Share on other sites More sharing options...
Stang70Fastback Posted November 19, 2009 Share Posted November 19, 2009 I honestly thought this was a "warm-up feature" or something. The car will do it for like a minute and then the revs will gradually come down as the car warms up. I honestly think it's just warming up the car quicker. If you blip the throttle or shift the car into drive, it comes down - I guess since it figures you're going to drive now so it will act normal. I usually shift into drive and then flick it to neutral for a second to let the revs come down (since it takes a few seconds) that way the car doesn't jolt into gear. But yeah, I think the car is just warming up until you start driving. Maybe not tho, it's done that for the whole time I've had the car anyway (which started at like 180-190k tho, lol. Link to comment Share on other sites More sharing options...
chitty chitty bang bang Posted November 20, 2009 Author Share Posted November 20, 2009 The Choke? Where is that on the car? I'm not sure about it being a warm up feature even though that is a comforting thought. This started very recently... (around 135k)... Link to comment Share on other sites More sharing options...
DPSubie Posted November 28, 2009 Share Posted November 28, 2009 Same thing in my 2001. Although when I press in the clutch, it seems to make it rev even higher which seems kinda weird to me as well. Link to comment Share on other sites More sharing options...
Gimpy117 Posted November 29, 2009 Share Posted November 29, 2009 my 1990 does the same thing. wont even go to 4th gear till it warms up. Link to comment Share on other sites More sharing options...
streetlethal1000 Posted December 11, 2009 Share Posted December 11, 2009 Same thing in my 2001. Although when I press in the clutch, it seems to make it rev even higher which seems kinda weird to me as well. Well I would guess this is becaue there is less resistance on the engine and the revs go even higher. Mine does the same thing as the rest of you. In the cold it revs up. Give it a minute and then tap the gas and it comes back down again. Where does the idle settle for you guys? Mine is about 500rpms and smooth once its warm. If I try to put it in gear and move away while its still reving the engine doesnt like it too much. Its grumbles at me a bit. I heard about cleaning the IAC. Anyone try this? Link to comment Share on other sites More sharing options...
anothernord Posted December 11, 2009 Share Posted December 11, 2009 Perfectly normal. The car idles high when it is warming up so it can heat up faster and expand the rings and more quickly. The idle adjustment screw doesn't actually change the idle; the ECU completely controls idle. Link to comment Share on other sites More sharing options...
Stang70Fastback Posted December 13, 2009 Share Posted December 13, 2009 Well I would guess this is becaue there is less resistance on the engine and the revs go even higher. Mine does the same thing as the rest of you. In the cold it revs up. Give it a minute and then tap the gas and it comes back down again. Where does the idle settle for you guys? Mine is about 500rpms and smooth once its warm. If I try to put it in gear and move away while its still reving the engine doesnt like it too much. Its grumbles at me a bit. I heard about cleaning the IAC. Anyone try this? Yeah, until it warms up, I think it still idles a bit higher, so it makes the whole car vibrate a bit in gear once I come to a stop, until it warms up. Mine normally idles somewhere around 6-700 RPM. I've actually got some issue I need to resolve. SOMETIMES when I come to a stop the car seems sick and I realize it's because it's idling at 500 and running rough. Then after a few minutes it goes back to idling a bit higher and everything's fine. I think the IACV is being a bit finicky.... Link to comment Share on other sites More sharing options...
