mgwinn Posted November 17, 2009 Share Posted November 17, 2009 I have a 95 Subaru Legacy and have been having problems for almost a year now. It started because of the cold weather and it sat for a few days, so it wouldn't start. Since then, I've changed the battery, coil, spark plugs, and fuel filter, but no luck. It's to the point now that it will start, but as soon as a let off the gas it dies. What is the problem??? Link to comment Share on other sites More sharing options...
Bdubs Posted November 17, 2009 Share Posted November 17, 2009 All the intake parts connected? No Vacuum leaks? Link to comment Share on other sites More sharing options...
mgwinn Posted November 17, 2009 Author Share Posted November 17, 2009 not sure..im not that car savy..but I've had a few people look at it and not sure what's wrong, but they weren't that familiar with Subarus either. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted November 18, 2009 Share Posted November 18, 2009 Is yours MAF clean? If that gets anything on it. I will make proformance bad. Link to comment Share on other sites More sharing options...
Bdubs Posted November 19, 2009 Share Posted November 19, 2009 Check to make sure your air cleaner box (big black box on the pass. side wheel well) is sealed tightly, and the tubes aren't loose or cracked. That'd be the first step to see if there is anything amiss in that area. Link to comment Share on other sites More sharing options...
one bad bg Posted November 19, 2009 Share Posted November 19, 2009 fuel pump Link to comment Share on other sites More sharing options...
HeathyVT Posted November 21, 2009 Share Posted November 21, 2009 Could also be a cam sensor, I just replaced mine , due to rough starting and hesitation(almost like a fuel cut) Link to comment Share on other sites More sharing options...
WESTcoast Posted November 21, 2009 Share Posted November 21, 2009 how easily does it want to start, does it have trouble getting it to crank, does it crank sometime and then sometimes you will get nothing? If so I had it where my starter went out, I could start my car but it wouldn't hold an idle. Link to comment Share on other sites More sharing options...
DN1911 Posted November 25, 2009 Share Posted November 25, 2009 cam sensor, crank sensor, vacuum leak, and other major electrical issues can all cause this. are you getting a super high idle when you start it? this would indicate a vacuum leak Link to comment Share on other sites More sharing options...
