Stang70Fastback Posted November 15, 2009 Share Posted November 15, 2009 Ok, so I did my brakes myself this weekend. First time I've ever done it. It's really not that hard, which is pretty crazy. However, I've hit a snag. When I removed the right rear pad, I noticed it was unevenly worn (more on one side than the other). The caliper slider thing is frozen on one side (the side with the bolt - which I can't break loose). So that explains the uneven wear. It also means I can't extend it back enough to fit the new pad over the new rotor... any suggestions for how to break it loose? I'm going to try and get a big enough c-clamp to just compress it until it hopefully snaps loose... This is my 98 OBW by the way. Link to comment Share on other sites More sharing options...
iNVAR Posted November 17, 2009 Share Posted November 17, 2009 soak with pblaster. work the part in and out to loosen it. Link to comment Share on other sites More sharing options...
