coSTIgan-GT Posted November 15, 2009 Share Posted November 15, 2009 I need to mount 3 toggle switches that are easy to reach. I have gauges in the cubby, so thats a no-go. I don't want to just stick them anywhere or cut up my dash. The only things I can think of are mounting them overhead near the map lights, in place of the ashtray/cig lighter, or moving the info display to the ashtray and mounting the switches below the cubby. Does anyone have any other ideas? Pics? I am using the "aircraft style" switches. Thanks Link to comment Share on other sites More sharing options...
Darkness of Death Posted November 16, 2009 Share Posted November 16, 2009 you can always drill a hole on the shifter bezel. that would be an ideal spot... or...along the plastic trim...right of the driver's leg area..or even over would be cool i think Link to comment Share on other sites More sharing options...
TSiWRX Posted November 17, 2009 Share Posted November 17, 2009 Those "covered aircraft-style" switches are pretty big....I think you'll need to obtain replacement panels for your car, if you are intent on reverting the interior as-stock, later. I've got a couple of ancillary switches off to the left of the steering column, near the factory mirror/dimmer/wiper-de-icer panel, and I obtained a replacement panel (driver's side dash trim), just in case I ever wanted to go back to un-modified stage, for the interior. http://i170.photobucket.com/albums/u259/TSi_WRX/WinkyInsideDaycenterconsoleUNLIT2.jpg Sorry for the dirty console, as well as the blurry picture - the pic was meant as a quickie for my speed-detection countermeasures friends, not all of whom are fellow "car guys." However, I think this may give you an idea of what the ashtray conversion would look like. That's just a slightly modified small RadioShack "project enclosure," serving as the surface blank, into which I mounted the switchgear. <-- I love Winky, my "periwinkle" (ABP) LGT! - Allen / Usual Suspect "DumboRAT" / One of the Three Stooges '16 Outback, '16 WRX, 7th Subaru Family Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted November 30, 2009 Share Posted November 30, 2009 I've come up with a few. I'm hiding 4 switches in the top of inside of the left knee fuse door, hanging down. I have one installed at my right knee on the side plastic (my blackout aux displays switch). I thought about putting 3 in the plastic behind the map lights, hanging down. That would be sweet and no one would really notice, and it would be like flying a plane I recommend putting your in the ash tray area where TSI+WRX has his laser module. Or you can hide them under the shifter boot leather, making the rocker style. A guy on NASIOC did this, and it is a win. If none of those work... What are these switches for? [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
