dante2699yahoo.com Posted November 15, 2009 Share Posted November 15, 2009 Oh I'm havin a good time puttin in my new tranny. Started at 1030am. What a long day. Now I'm fixed a tranny support bolt problem. Yeah the weld on the nut broke and had to drill a in the floor board.(A couple of hole) No happy about that. So I hav to find sumthin to cover the big ass hole. Any Ideas? And when drillin the hole. Being that I didn't know wherre the nut was. I drill between the case. So I hav to cover thats up too. Just a long day and ready to be done with it. Another couple of hours. Urrghhh Link to comment Share on other sites More sharing options...
rmb2485 Posted November 15, 2009 Share Posted November 15, 2009 About $5 for 100 1" flexible plastic hole plug covers... http://www.mcmaster.com/#plug-covers/=4ihzzr In the future, try to push the broken bolt up through the hole, then stick a center punch in ad give it a good enough wack to dent the metal on the other side. Then drill where you see the dent. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted November 15, 2009 Author Share Posted November 15, 2009 Ok I hav another problem. Ok I put the tranny in. And it shifts fine with the car is off. But when the engine is runnin. It doesn't want to shift. What could be goin on? Link to comment Share on other sites More sharing options...
rmb2485 Posted November 15, 2009 Share Posted November 15, 2009 Your clutch isn't disengaging. Check to make sure everything is installed properly. edit: FYI, I happened to be in Lowes this morning, and they have those plugs in the drawers in the hardware section. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted November 16, 2009 Author Share Posted November 16, 2009 Yeah, I got one. But now I hav to find a patch. lol. I will hav to take pix. I had to drill like 4 holes. Yes I know. I'm a rookie. But oh well. Like you said. it will be covered up by the carpet. lol. Yeah everythin is hooked up. Like it shifts into gear when the car is off. But when the engine is runnin. It will not engage. I'm puzzled. Thanks with all the help. Link to comment Share on other sites More sharing options...
rmb2485 Posted November 16, 2009 Share Posted November 16, 2009 Your clutch isn't disengaging from the flywheel. If all your linkages and hydraulics are installed properly, there must either be a problem with the pressure plate or throwout bearing, or something inside the transmission that you can't see is binding. Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted November 17, 2009 Author Share Posted November 17, 2009 So I'm guessin I'm goin to hav to drop the tranny again? Damn! Link to comment Share on other sites More sharing options...
DN1911 Posted November 25, 2009 Share Posted November 25, 2009 Your clutch isn't disengaging from the flywheel. If all your linkages and hydraulics are installed properly, there must either be a problem with the pressure plate or throwout bearing, or something inside the transmission that you can't see is binding. auto or manual?? Link to comment Share on other sites More sharing options...
dante2699yahoo.com Posted November 25, 2009 Author Share Posted November 25, 2009 I got to engage. I hav to granny shift it. and then it came around. Thanks for all the help.. Link to comment Share on other sites More sharing options...
Clalaymn Posted November 29, 2009 Share Posted November 29, 2009 Does the Z4M and E46 M3 have the same transmission? If not, are the two transmissions interchangeable? Link to comment Share on other sites More sharing options...
