GrampsWRX Posted November 12, 2009 Share Posted November 12, 2009 Will the new STI brembos in black bolt right up to the leggy? I know I would have to get 04 STI rotors, but will the calipers work? Link to comment Share on other sites More sharing options...
hakgwai Posted November 13, 2009 Share Posted November 13, 2009 assuming u talkin about the 08+ sti brembos fronts do but not the rears Link to comment Share on other sites More sharing options...
HarryN Posted November 13, 2009 Share Posted November 13, 2009 You could also look into this: http://www.importimageracing.com/p/Stoptech-LGT-332mm-4-wheel-Big-Brake-Kit.html Contains all the hardware you need to bolt up the brakes to your Leggy. Pricey, but Stoptech makes some great brake systems. And in case you want to stick with Brembo brakes: http://www.fredbeansparts.com/servlet/the-925/Brembo-Subaru-Legacy-GT/Detail Read the paragraph about the rear Brembo brakes and what you'd need. Link to comment Share on other sites More sharing options...
JSK05LGT Posted November 14, 2009 Share Posted November 14, 2009 The 08 Fronts will, the 08 rears will not, and there is no adapter for the 08 Rears to make them work. You can do what I did and buy the 08 Fronts and a set of 05 Rears and have them painted to match, then you simply need the adapter brackets (fastwrx.com) and a set of either DBA Adapter Rotors, or the Onkel Racing setup. Of course you will also need pads and new lines are recommended for proper fitment. Link to comment Share on other sites More sharing options...
