phenryiv1 Posted November 7, 2009 Share Posted November 7, 2009 I have autoXed the 2.5i with relatively consistent tire pressures, but after 2-3 runs, pressures climb and I lose grip. How should my HPDE session tire pressure (at start) compare to my AutoX pressure? I run around 42F/40R for autoX. My track session will be around 20 minutes. TIA (PS- the event is TOMORROW!!!) Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
SubyShop.com Posted November 7, 2009 Share Posted November 7, 2009 In general I start with lower pressures taking it easy the first lap or two to get the brakes and tires up to temp. After a session I check the pressure and if it is way too high I will drop a few psi out. Last event I did I ran 34 PSI and it didn't deviate from that value much at all (nitrogen fill and super stiff sidewalls). What tire are you running? -Franz Link to comment Share on other sites More sharing options...
phenryiv1 Posted November 7, 2009 Author Share Posted November 7, 2009 In general I start with lower pressures taking it easy the first lap or two to get the brakes and tires up to temp. After a session I check the pressure and if it is way too high I will drop a few psi out. Last event I did I ran 34 PSI and it didn't deviate from that value much at all (nitrogen fill and super stiff sidewalls). What tire are you running? -Franz 215/45/17 BFG G-Force T/A Patrick Looking for spacers or adapters to install aftermarket speakers in the doors of your Legacy? CLICK HERE or PM me! http://www.carstereoadapters.com./ Link to comment Share on other sites More sharing options...
wpmarky Posted November 9, 2009 Share Posted November 9, 2009 I start at 36 with cold tires, after the run it's usually around 40-42 when the tires get hot. Link to comment Share on other sites More sharing options...
FPerron Posted November 10, 2009 Share Posted November 10, 2009 I run the same tires as you but 245/40/17, and I start with 32 and end up with 40 after 4 or 5 laps. Link to comment Share on other sites More sharing options...
