skaterblaze Posted November 4, 2009 Share Posted November 4, 2009 i have a 91 legacy with a STOCK 97 outback phase 2 (EJ222) (142bhp) 2.2L SOHC engine swap (weak I know) and i was wondering if i could install a turbo. what turbo can i install..i'm guessing a stock legacy turbo VF11 and what other stock parts like injectors, fuel pump, radiator ect. HAD to be replaced to handle the turbo? and whats the max psi the stock engine can handle thanks much. oh ya i believe the compression ratio is 9:7:1 and I plan on only low boost application like 8-10 psi anyways. thanks much,Blaze:rolleyes: SUBI-POW! Link to comment Share on other sites More sharing options...
skaterblaze Posted November 14, 2009 Author Share Posted November 14, 2009 nope. it could be possible if the compression was under 9:1 but not over. might as well just drop some TNT and blow it up. Link to comment Share on other sites More sharing options...
05lgt5spd Posted November 14, 2009 Share Posted November 14, 2009 I would think it would be ok. When I had my gsr 11:1, I was told it was ok to run 12lbs daily. You can have higher compression, and run a turbo, but you need to keep the temps down to not detonate. But honestly in your case, you would be better off swapping a 2.0l wrx motor in there Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 14, 2009 Share Posted November 14, 2009 do a swap, get lower compression pistons, or limit boost to about 5 lbs.......if you want it to last anyways. Link to comment Share on other sites More sharing options...
skaterblaze Posted November 15, 2009 Author Share Posted November 15, 2009 i think i'll save for the swap. but should i go for the wrx 2.0l or the twin turbo? maybe i'll just save up and find a turbo legacy and upgrade it a lil since it will have the turbo engine and tranny, but i would get more horse with a swap. but then i need a turbo tranny and clutch kit.hmm Link to comment Share on other sites More sharing options...
shtbxr22 Posted November 15, 2009 Share Posted November 15, 2009 you'll have to convert to RHD if you do the twin. left turbo will not like the master cylinder. do a 2.0 wrx swap. the trans will bolt up just as well, just make sure you start saving for a new trans. Link to comment Share on other sites More sharing options...
05lgt5spd Posted November 15, 2009 Share Posted November 15, 2009 dont do the twin dude, stick with a really stout fairly cheap setup. there is a low mileage wrk engine on craigslist with all the drivetrain for under 3k. You would spend more than that putting a turbo on your car. Link to comment Share on other sites More sharing options...
Bumpty Posted December 8, 2009 Share Posted December 8, 2009 Put a wrx donk in. The question you should be asking, is which one! Link to comment Share on other sites More sharing options...
skaterblaze Posted December 9, 2009 Author Share Posted December 9, 2009 any EJ i know. but which one. and one i can afford. maybe an old 2.0T Link to comment Share on other sites More sharing options...
shtbxr22 Posted December 9, 2009 Share Posted December 9, 2009 old 22T best subaru engine made. Link to comment Share on other sites More sharing options...
sqc151 Posted December 9, 2009 Share Posted December 9, 2009 old 22T best subaru engine made. x 100000000000000000000 Link to comment Share on other sites More sharing options...
timmafod Posted December 9, 2009 Share Posted December 9, 2009 I turboed the stock EJ22 in my '97 outback sport SOHC (single port head). Ran 8psi summer, 7psi winter for 3 years, ~60k miles until a month ago when I got T-boned. Car still has great compression and leakdown numbers, 164xxx miles. Such a good daily driver...sigh. I decided to make it quickly & on the cheap using scrap I had lying around. I used the stock "header", made an up pipe from there to a used Garrett GT2560R and downpipe to mate to the factory catback, which I quickly replaced with a Greddy EVO2 catback. Got a used WRX intercooler from nasioc, emanage blue for spark and some fuel trims, Vortec FMU for fuel. Original pump & injectors. It worked great IMHO, easily overwhelmed the open diffs and cheap tires I put on the thing. I guess I'm selling the entire setup, once I hear back from the insurance company Link to comment Share on other sites More sharing options...
skaterblaze Posted December 10, 2009 Author Share Posted December 10, 2009 I know. the 2.2 Turbo had a super dank engine. problem is it only runs 163hp stock and the 2.0 Turbo runs 227hp @ 4000rpm stock or I could get the DOHC 2.2 T that pushes 276bhp @ 6000rpm 268 ft lbs @ 3200rpm. problem is the DOHC is Interface. which means if my timing belt blows. so does my engine basically. but now that i'm reading up. i have a 1997 outback EJ222 142bhp and Wikipedia says that ALL DOHC & 1997 EJ engines and up are Interface!! is this true??! I gotta watch out on mine if so. help please. I'm really thinking about getting a DOHC EJ257 300hp. If I go DOHC. Link to comment Share on other sites More sharing options...
