peteyjr Posted October 31, 2009 Share Posted October 31, 2009 Got got back from the dealer. They changed the relay to the fan switch. I'm sure many of you have done this. I was under the impression that they needed to change the ECU as well. They said not. What gives? Link to comment Share on other sites More sharing options...
05 GT LTD Owner Posted October 31, 2009 Share Posted October 31, 2009 Only if your fan was constantly running. If not, you caught it in time. This service program will involve replacement of the Radiator Cooling Fan Relay 2. It will also involve checking the ECM radiator cooling fan circuit for proper operation. If it is determined that the ECM radiator cooling fan circuit has been damaged, replacement of the ECM will also be necessary. Link to comment Share on other sites More sharing options...
