BillyJoe Posted October 31, 2009 Share Posted October 31, 2009 Hey All I'm been happy with my Eibachs now for a couple months but I can't help to wonder if things can be improved. I know the Eibachs were designed for our USDM stock struts but what do you all think if I mixed it up with Bilsteins? Has anyone done this? Will it change the ride height? Thanks ahead of time for your opinions Link to comment Share on other sites More sharing options...
scoobydoobie Posted October 31, 2009 Share Posted October 31, 2009 your front end will be higher than it is now Link to comment Share on other sites More sharing options...
kneedragger Posted October 31, 2009 Share Posted October 31, 2009 I agree. I put eibachs on my bilsteins a couple of months ago and with the positive charge in the billies the front height is sky high. Looked ridiculous so they came off the same day. Link to comment Share on other sites More sharing options...
BillyJoe Posted November 1, 2009 Author Share Posted November 1, 2009 ok great, i remembered reading somewhere that my front end with be a little high. Thanks for the input! Link to comment Share on other sites More sharing options...
goneskiian Posted November 3, 2009 Share Posted November 3, 2009 Get the Koni's to avoid the front end getting jacked. I believe the Tokico's use the same top hats the Bilsteins use so will likely be jacked up as well. If you're dead set on the Bilsteins, find springs designed for them. I'm really loving my Eibach and Koni setup! Cheers! Link to comment Share on other sites More sharing options...
