spongemonster Posted October 30, 2009 Share Posted October 30, 2009 Well being a 2.5i I have the basic stereo. Recently the selector button for switching between cd, sat, aux, and radio stopped working properly. Now it only switches between cd and radio. When I push the aux or sat button nothing happens. Previously an RCA adapter was added to the stereo. Any idea what might have come off to cause that issue? I don't really want to pull apart the entire center console to trace a problem that could be internal. I also don't really want to go to an aftermarket deck as the stock one does almost everything I want. Link to comment Share on other sites More sharing options...
SVXdc Posted October 31, 2009 Share Posted October 31, 2009 Do you have the sat tuner module, or is it just Aux mode that's not working? It's not uncommon for the switch inside the 3.5mm jack to fail. That tells the radio when you've plugged a plug into the jack, which allows you to change into Aux mode. With no 3.5mm plug present the Aux button is inactive. Link to comment Share on other sites More sharing options...
