PSZCZ.lgt Posted October 22, 2009 Share Posted October 22, 2009 So last night i started to notice some resistance when ever i put my car in first gear, It is a 2005 gt m/t stage 2. The more i drove i noticed resistance as i put in and took out of all the gears. Sometimes i can fly through the gears with no problems but others i can barely get it in! I called a subau dealership this morning and they told me if my clutch felt normal (release speed and catching) to check my transfluid ?? This happen to anyone? Is my clutch on its way out? Link to comment Share on other sites More sharing options...
Darkness of Death Posted October 22, 2009 Share Posted October 22, 2009 usually it's that your clutch would be slipping if it's on the way out. Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted October 22, 2009 Author Share Posted October 22, 2009 yeah but its not, dont kno what to think! Link to comment Share on other sites More sharing options...
Darkness of Death Posted October 22, 2009 Share Posted October 22, 2009 have you checked your clutch fluid? Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted October 22, 2009 Author Share Posted October 22, 2009 no im guna check get the trans fluid n clutch fluid, if not guess i have to make it stock and bring it in hope itll get warrentyd Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted October 22, 2009 Author Share Posted October 22, 2009 bump Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted October 23, 2009 Author Share Posted October 23, 2009 bumpski help Link to comment Share on other sites More sharing options...
AShoe Posted October 23, 2009 Share Posted October 23, 2009 Sounds like either the throw out bearing, or slave cylinder. I would bleed the clutch master and slave cylinder and see if that helps. I think you can reach up from underneath the car and see if there is much play in the throw out bearing. Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted October 23, 2009 Author Share Posted October 23, 2009 ok, i gotta search for all this, not to experienced at all with trans stuff Link to comment Share on other sites More sharing options...
PSZCZ.lgt Posted October 24, 2009 Author Share Posted October 24, 2009 bleed the clutch master n slave cylinder!! no problems getting in an out of gear, clutch now feels lighter, kinda like my friends 07 wrx tr??? Link to comment Share on other sites More sharing options...
