jasonheyd Posted October 20, 2009 Share Posted October 20, 2009 This past Friday I had new Blizzak LM-60s snow tires put on my 2010 LGT. I didn't actually drive the car all weekend but today, on my way home from work, the TPMS warning indicator lights up. So, I pull into a gas station to see if there's a problem. I check all four tires, and find that all of them are reading 52+ PSI instead of the 33/32 that I would expect. I run them down to where they should be, and the TPMS warning light goes dark. So, yeah... I haven't called the place that mounted the tires (I'll do that tomorrow), but I'm wondering if the 160 miles that I drove at over 50 PSI might have damaged the tires. Any advice? (...or thoughts as to why the ____ someone would pump a tire up to 50 PSI when it says right on the tire that running over 40 = asploding tires & probable death by out of control careening across the interstate?) Link to comment Share on other sites More sharing options...
Balrock Posted October 21, 2009 Share Posted October 21, 2009 The duche probably looked at the max load and filled it up to there. I had a second set of tires mounted on the spare rims and filled with nitrogen. The guy told me when I picked them up he did not know what they were going on so they max inflated them. At leat I did not have some fool just let me put them on anddrive off. I would think your tires would be fine, but I would definatley call them up and ask WTF? Link to comment Share on other sites More sharing options...
trackhore Posted October 21, 2009 Share Posted October 21, 2009 your tires will be fine. Link to comment Share on other sites More sharing options...
jasonheyd Posted October 21, 2009 Author Share Posted October 21, 2009 Thanks for the replies... Went to work & back today with no TMPS alarm flashing on the dash, so hopefully things are back to normal now. *knock on wood* Link to comment Share on other sites More sharing options...
Legend Posted October 22, 2009 Share Posted October 22, 2009 I got the new LM-60's last week also. So far so good. I did a couple runs to 110mph and they run nicely. Yesterday I drove 4 hours in a rain/snow mix at 55-65mph and the car felt really solid. 52psi is dumb... but I haven't checked what they put mine at... I better go check it out! My '05 LGT My '07 Supercharged Shelby Link to comment Share on other sites More sharing options...
jasonheyd Posted October 22, 2009 Author Share Posted October 22, 2009 If you're doing track runs and hitting those speeds, I think you'd notice if they were at 50... I felt like I was bouncing a pontoon boat down the Mass Pike at 60-70 MPH. I never imagined someone would put the tires on the car at max pressure & let me drive off, so I was just wondering if the Blizzaks were that funky & different from the stock Potenzas. They're definitely different, but the car feels a lot less like a pogo-stick now. Link to comment Share on other sites More sharing options...
