stanghater Posted October 19, 2009 Share Posted October 19, 2009 So I have had a problem for about a year now with my 05 LGT Wagon. THe car rides and drives fine, but when you hit the brakes, it shimmies HARD. I mean hard. scary hard. I have done new brakes and rotors twice and checked all the wheels for balance. The car doesnt shimmy at all when you dont push the brakes, just when you brake. its really bad at hgh speeds, and not so bad at lower speeds can you guys help? Link to comment Share on other sites More sharing options...
Sebastian Posted October 19, 2009 Share Posted October 19, 2009 Are you using OEM brake pads, if so ditch them. Link to comment Share on other sites More sharing options...
stanghater Posted October 19, 2009 Author Share Posted October 19, 2009 no i have new oem rotors (from subaru) and Hawk hps pads Link to comment Share on other sites More sharing options...
iyalla Posted October 19, 2009 Share Posted October 19, 2009 What do you mean shimmy? You mean like a pull to the left or right?? It may be a sticky caliper. Try driving for a half hour or so then pull over and place your hand on each wheel, see if one of the wheels feels hotter than the others. Link to comment Share on other sites More sharing options...
stanghater Posted October 19, 2009 Author Share Posted October 19, 2009 its a shake, shimmy at low speeds and a violent shake at high speeds Link to comment Share on other sites More sharing options...
OGG Posted October 20, 2009 Share Posted October 20, 2009 Warped or contaminated rotors or(if your lucky) bad wheel balance(but I doubt it). Link to comment Share on other sites More sharing options...
Sebastian Posted October 20, 2009 Share Posted October 20, 2009 Have you had the alignment checked? Link to comment Share on other sites More sharing options...
stanghater Posted October 21, 2009 Author Share Posted October 21, 2009 haven checked the alignment yet, would that do it? Im gonna try to re bed the pads this weekend Link to comment Share on other sites More sharing options...
Sebastian Posted October 21, 2009 Share Posted October 21, 2009 I'm no expert but I believe alignment can cause vibrations while braking. I think tire shops offer free alignment inspections. Link to comment Share on other sites More sharing options...
meier motor sports Posted October 21, 2009 Share Posted October 21, 2009 you said they are new rotors and you still get the shimmy. there is possibly debrie between the rotor and hub or a bent hub or just the rotor is bad. (some times the parts stores drop them) Link to comment Share on other sites More sharing options...
meier motor sports Posted October 21, 2009 Share Posted October 21, 2009 I'm no expert but I did stay at a holiday in last night Link to comment Share on other sites More sharing options...
stanghater Posted October 21, 2009 Author Share Posted October 21, 2009 you said they are new rotors and you still get the shimmy. there is possibly debrie between the rotor and hub or a bent hub or just the rotor is bad. (some times the parts stores drop them) wouldnt that cause it to shake all the time? Link to comment Share on other sites More sharing options...
