BrownBoy Posted March 22, 2005 Share Posted March 22, 2005 Okay, I installed new bulbs in my foglights, and I noticed that the projector in one of my foglights is facing downward, unlike the other side. I tried tightening and loosening the little screw to the left of the light assembly when the foglight cover is off, but it did not do anything. I don't know what else to do, I know that it is not the way it should be. If you guys dont understand what I'm saying, I'll post pics, but is there any other way to adjust JUST the projector and not the whole unit. Thanks for any help guys...I would go to the dealership and have them look at it, but I could probably get an answer quicker here... Link to comment Share on other sites More sharing options...
sleepin gt Posted March 22, 2005 Share Posted March 22, 2005 just make sure your bulb is securely in the slot its supposed to be in. make sure the notch is lined up from the housing to the bulb. hopefully its that easy! Link to comment Share on other sites More sharing options...
BrownBoy Posted March 22, 2005 Author Share Posted March 22, 2005 ok..here are some pics... the one with the red outlining shows the gap that is there between the housing and the projector; the other pic shows the left foglight, which is okay (for comparison purposes) Link to comment Share on other sites More sharing options...
Guest *Jedimaster* Posted March 23, 2005 Share Posted March 23, 2005 It appears that you have a gap between the housing and projector. Fix it. Link to comment Share on other sites More sharing options...
