specialB Posted October 6, 2009 Share Posted October 6, 2009 I hear its not a good idea to run a CAI with most tunes...when reading my air fuel ratio from the monitor it stays 11.1 all the way thru the rpms at wot. Should I be worried about it? I was told thats a safe number. Is there anything else I should look at to be sure the CAI isn't affecting anything? Link to comment Share on other sites More sharing options...
spec.B Dream Posted October 7, 2009 Share Posted October 7, 2009 The stock O2 sensor is not accurate at WOT. You would need to install a WB02 post-turbo to get accurate AFT. From what I've read, it is generally not advised to run aftermarket intakes unless you get a specific tune, and then, only if you really need it. The stock intake is very good until you start modding for big power (in which case you would need to get a tune anyway). Link to comment Share on other sites More sharing options...
specialB Posted October 7, 2009 Author Share Posted October 7, 2009 So I've heard but what a waste of 250 bucks! I have all the stock stuff at home maybe I'll try to sell the AEM.. Link to comment Share on other sites More sharing options...
