uniqsol Posted October 3, 2009 Share Posted October 3, 2009 My rear wiper is dead on my 96 wagon. I need to fix it, but how do I know if it is the switch or the motor? Also, is replacing a wiper motor a big deal? Are they difficult to get to? Link to comment Share on other sites More sharing options...
eekay Posted October 7, 2009 Share Posted October 7, 2009 You should probably be able to check if the problem is the motor by using a multi-meter or test light to make sure power is reaching the wiper motor when the switch is engaged. This should only take a few minutes to check. As far as replacing the motor, it shouldn't take you any longer than maybe 45 minutes from start to finish (assuming you know nothing about the replacement at all.) Removing the door panel is a piece of cake and the motor housing is only 3 bolts if I remember correctly. It should be rather straight forward once you see it. Good luck! My 9.3 cups EJ22 makes me feel like my **** is 2.8 decimeters! Link to comment Share on other sites More sharing options...
uniqsol Posted October 8, 2009 Author Share Posted October 8, 2009 Good info, thanks! Link to comment Share on other sites More sharing options...
