supafla777 Posted September 28, 2009 Share Posted September 28, 2009 well guys as i slowly start putting my personal signature on my car, now its time to get rid off the stock rims and tires and put some different one. since i am no expert in this field, i have chosen one setup and would like to run it by the experts and get your opinion. for Rims size are 18" Size: all 4 Rims are 18x7.5 about 2 1/2" Lip. About 22.8 lbs ea Bolt Pattern 5 lugs : 5x100 and 5x114.3 Offset: +42mm Will they fit ?? are they ok For tires i would like to put 235/40-18 for front, ( will fender rolling be needed ) and would like to have the wider tire looks in the back, so i was thinking 285/30/18. If not i am open to any good suggestion. one thing i am from Chicago capital city of the giant crater size potholes, so low profile tires are not an option. Link to comment Share on other sites More sharing options...
krzyss Posted September 28, 2009 Share Posted September 28, 2009 Why did you buy AWD car if you want to have wider tires in the back? Krzys Link to comment Share on other sites More sharing options...
jayway Posted September 28, 2009 Share Posted September 28, 2009 Those are the same specs of my TE37's and they fit fine. I run 225/35/18. Do some searching in the wheels and tires section and you will find some good info. You can't run 285's in back, 7.5 width will only fit 235 max, and thats even pushing it. You want the same size tires all the way around on an AWD car. Link to comment Share on other sites More sharing options...
supafla777 Posted September 28, 2009 Author Share Posted September 28, 2009 thanxs for the info guys. well the wider tire come up as an idea, since i saw a local dude running it on his wrx and trust me it looked sick. once again i am no pro, thats why i am asking before i make any mistakes. Link to comment Share on other sites More sharing options...
