subiedude Posted September 22, 2009 Share Posted September 22, 2009 I had Elbach lowering springs installed a few years back. Although they handled pretty nicely with my Perrin F/R anti sway's... they were beyond harsh if I hit a bump, let alone a pothole. I live in NJ, and with snow and ice... there are always potholes you can't see to avoid. I hit one once, and got bubbles in 2 of my tires which I already replaced. I also re-installed the stock springs. About a year or so has gone by since. I noticed the car making a "Runt-Runt" sound whenever I go over a bump or up a ramp. When I had the pads replaced, I had it looked it. The strut was leaking fluid. I don't know jack about the internals of a strut, but don't think that is a good thing. I do not do any track work in my car... just looking for some advice with what to replace them (assuming I need to replace the front as a pair) if not all four. Link to comment Share on other sites More sharing options...
madcatz Posted September 22, 2009 Share Posted September 22, 2009 KYB G2 is a aftermarket stock replacement strut.I just have been talking about struts here:http://legacygt.com/forums/showthread.php?t=120979if you care to look lol -Travis Rob (rao) you're a fine gentleman, thanks I guess. Link to comment Share on other sites More sharing options...
goneskiian Posted September 23, 2009 Share Posted September 23, 2009 If you can swing all four get the Koni struts. Yes, madcatz's thread is a very good read. If you're really tight on cash you can probably find another owner here unloading their relatively lightly used stock struts and you should be able to get a front set for less than $100. Cheers! Link to comment Share on other sites More sharing options...
subiedude Posted September 23, 2009 Author Share Posted September 23, 2009 Wow. Awesome link. Will carefully read thru this. Thank you both! Link to comment Share on other sites More sharing options...
schwinn Posted September 23, 2009 Share Posted September 23, 2009 Stock struts + aftermarket/stiffer springs = dead strut. Maybe the GR2s will hold up better, but struts and springs should always be considered a matched-set... Link to comment Share on other sites More sharing options...
subiedude Posted September 24, 2009 Author Share Posted September 24, 2009 Stock struts + aftermarket/stiffer springs = dead strut. Maybe the GR2s will hold up better, but struts and springs should always be considered a matched-set... I wish I knew that equation already..... Link to comment Share on other sites More sharing options...
subiedude Posted September 24, 2009 Author Share Posted September 24, 2009 After reading that thread... I lean a bit towards that Tokico HTS. How do you adjust them? Although the job market has more to say in what I do at this point. Link to comment Share on other sites More sharing options...
