1astrokeit Posted September 17, 2009 Share Posted September 17, 2009 im doing my up pipe and down pipe install tomorrow at work. i got all gaskets from dealer, got a grimmspeed up pipe, cobb dp,anything i would need before i hack into it? do you have to pull intercooler off to change these parts? Link to comment Share on other sites More sharing options...
rurouni_x Posted September 17, 2009 Share Posted September 17, 2009 No need to take IC off just unbolt the pass side manifold and jack up the motor a bit to get the up out. Other than that just be careful when removing the UP watch out for the half moon seals an the crank case. If you accidental push one in it will leak oil and you will have to replace it which is a PIA. Link to comment Share on other sites More sharing options...
scoobydoobie Posted September 17, 2009 Share Posted September 17, 2009 Get some PBblaster Link to comment Share on other sites More sharing options...
1astrokeit Posted September 17, 2009 Author Share Posted September 17, 2009 i have all that stuff at work. what half moon seals? where are they located? Link to comment Share on other sites More sharing options...
1astrokeit Posted September 17, 2009 Author Share Posted September 17, 2009 can i use the oem dp bolts? Link to comment Share on other sites More sharing options...
rurouni_x Posted September 17, 2009 Share Posted September 17, 2009 they are plastic half circles located on the crank case cover and you can dislodge them pretty easily when trying to wrestle the UP out. Yes you can reuse the bolts . Link to comment Share on other sites More sharing options...
1astrokeit Posted September 17, 2009 Author Share Posted September 17, 2009 thanks for everyones help will keep you updated how things go. Link to comment Share on other sites More sharing options...
RedDawg Posted September 17, 2009 Share Posted September 17, 2009 a folding chair and a 6-pack to sit down for 15min and cool off when the bolts start pissing you off. Link to comment Share on other sites More sharing options...
1astrokeit Posted September 17, 2009 Author Share Posted September 17, 2009 I'm all ready for that. Lol Link to comment Share on other sites More sharing options...
