Woodstock Posted September 16, 2009 Share Posted September 16, 2009 I have a problem with my Greddy evo 2 hitting the rear sway bar; stiff setting (perrin 22m). The clearance between the exhaust and RSB is less than half inch (I can barely slide my finger in between). The exhaust shakes when I am in 1st and 2nd gear, or starting the car. I can hear it banging when Im going uphill at low speeds. 10 - 20mph I was thinking if there is a harder exhaust hanger, so that It can keep my exhaust from shaking or just place a heat resistant rubber in between. any thoughts on this? Link to comment Share on other sites More sharing options...
pillboy Posted September 16, 2009 Share Posted September 16, 2009 I have no idea how hot the exhaust pipe gets in that location, but if you go the rubber route, check the baking section in Target/Walmart for silicone hot pads, etc. I'm not sure what they can withstand, but it is probably at least 450 to 500 since recipes call for those baking temps. Silicone radiator hose would probably work too, but probably more expensive than a piece of silicone bakeware. It is still ugly. Link to comment Share on other sites More sharing options...
MeoW71 Posted September 16, 2009 Share Posted September 16, 2009 You could look at getting some urethane exhaust hangers. I know kartboy has some longer exhaust hangers that lower it some. However, the parts I've seen are for the WRX. I have no idea if they are the same for the legacy. Link to comment Share on other sites More sharing options...
Woodstock Posted September 16, 2009 Author Share Posted September 16, 2009 I find it nicely tucked in right now. But, I'd like it to get it tucked in a little bit more because I am planning to lower the car. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 16, 2009 Share Posted September 16, 2009 These are harder than stock http://www.fredbeansparts.com/servlet/the-1141/STi-Muffler-Hangers/Detail These are even harder http://www.flatironstuning.com/p-559-cobb-polyurethane-exhaust-hangers.aspx These are what I have (cheap and work just as well as any other polyurethane exhaust hanger bushings http://www.rallitek.com/raexhalamowr.html They stop your exhaust from bouncing around and hitting things. I'm surprised you didn't get them with your new exhaust. It's the $20 icing on a $600+ cake. Edit: some company (think it's kartboy, might be others too though, been a while) sells longer exhaust hanger bushings. I put one of those on at the hanger where the exhaust crosses the axle, because I had some fitment issues too. Anyways, know that there are good options available for all the people that have modified cars and bouncy stock exhaust hanger bushings. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Woodstock Posted September 17, 2009 Author Share Posted September 17, 2009 Ill give it a try. umm... do I need 5 pieces? I think I only need 3 or 4. I can't remember. Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted September 18, 2009 Share Posted September 18, 2009 there's 2 hangers on each muffler (4 total hangers there), and there is one hanger before the Y. So technically you would replace 5 (the total number on your exhaust. The thing will not bounce around after that. It's a cheap solution for an annoying problem. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
Woodstock Posted September 18, 2009 Author Share Posted September 18, 2009 thanks! I will get the rallitek exhaust. hopefully it won't bounce anymore. Link to comment Share on other sites More sharing options...
